Code p0500
Old Jan 19, 2004 | 05:31 PM
More Power's Avatar
Code p0500
Anyone get this code and how can you reset codes.
Old Jan 19, 2004 | 05:36 PM
phox_mulder's Avatar
P0500 No Vehicle Speed Sensor Signal
From http://www.troublecodes.net/chrysler/96-01.shtml
Should go away after the problem is corrected.
Could be either the sensor on the rear differential or on the transmission if the 6speeds have one.
I got that code when I had my Truespeed installed and one of the wires came disconnected.
My speedometer and odometer quit working though, so was a dead giveaway as to what happened.
phox
Old Jan 19, 2004 | 05:40 PM
More Power's Avatar
I just had clutch installed in my truck last week and have noticed noting just checked to see codes before resetting apps.
Old Jan 19, 2004 | 08:06 PM
Dr. Evil's Avatar
I have the same trouble code but havent had a chace to rectify it yet.....the sensor is on the diff - pull it off and clean the contacts....
It may be cleared by pulling off both battery cables and letting it sit for a couple of hours.....that should prolly take care of it.
For future reference:
http://www.obdii.com/
Old Jan 20, 2004 | 10:58 AM
roadrat's Avatar
I got this code because my abs light kept comming on whenever i hit a rough spot on the highway, temps were extremely cold (-30c) abs light always went out after restarting engine, hasn't happened again since the return of mild weather (-20c), havn't bothered to try and clear it yet, maby in the spring. Winter aint over yet.
rob
GFB
Nov 24, 2007 07:02 PM
lovinCTD59
Feb 10, 2007 01:59 AM
dssimecek
Jan 24, 2006 12:54 PM
K2Cummins
Dec 24, 2004 09:41 PM
figure_9_pro
Dec 5, 2004 08:29 AM
