steering shaft pulled out
Your set screw came loose on the shaft letting the upper shaft come out. Or you didn't watch for that when you installed the borg shaft.
The upper shaft is made to collapse on impact. Which means the lower shaft holds it in place.
I removed the set screw under the boot and pushed the shaft back up. I took out the lock washer and applied medium strength loctite. I can't move the shaft now but I thought I read somewhere that the shaft is suppose to move? When I have time their is hours and hours of reading searching through the posts.
Received 1,637 Likes
The Borgeson shaft was / is known for collapsing on itself from the setscrew not holding properly. This was documented years ago by several members including BobVA. Search his name and you will find his thread. He was almost killed when the shaft fell completely out. Luckily he wasn't traveling fast and coasted to the side of the road.
The factory shafts in trucks have a collapsible system with plastic, or aluminum pins which allow the steering assembly to compress in a high speed offset accident where you hit something that pushes the steering gear upwards towards the driver. Borgeson was required to do the same to prevent lawsuits where drivers were injured or killed by the steering column being pushed into the cab through a rigid intermediate shaft design (in theory) if they sold solid, non collapsing shaft.
For me, the idea that the intermediate shaft is going to launch by upper column into me isn't an issue, as if I hit anything that hard with a 1992 engineered rusty old truck, I've got bigger concerns than that steering column, as the precise impact required to skewer me is nearly impossible.
In my truck, I have a jeep Chevy c10 combination shaft in there, and once I had the length I needed to keep all straight, I drilled through both shafts joining them together with a grade 2 screw, preventing collapse unless a huge impact is experienced. A brass bolt or shear pin will work as well.
Not advising you to do the same, just telling you what worked for me.
Ditto - To make it easier for me to check, I marked the shaft with a white enamel paint pen. I check the mark on the shaft as part of my pre-trip inspection.
grwynn5592 (02-06-2024)
Jim Dynomite
02-11-2006 12:56 AM
OHFarmboy
02-25-2005 11:30 AM
