Steering shaft play at steering box
Old Oct 23, 2006 | 09:34 AM
jkap's Avatar
How much play should I have at the steering shaft as it goes into the steering box from the steering wheel? I had someone move the steering wheel back and forth, and the shaft going into the box moved about 30 to 45 degrees before the pitman arm moved.
Should there be Zero degrees difference here, or is a little play needed. Also, will the over center adjustment on top of the box tighten this up?
Old Oct 23, 2006 | 04:07 PM
JKM's Avatar
JKM
the over center adjustment will help this , but you should do the bearing pre-load first.
TSB here:
http://dodgeram.info/tsb/1997/19-10-97.htm
03CTDCO
Jan 12, 2011 06:23 PM
89dieselkong
Jan 8, 2011 12:41 PM
ram4tow
Aug 14, 2009 10:57 PM
4x4dually
Jan 5, 2007 01:07 PM
Fishbait
Jan 4, 2006 03:30 PM
