KDP carnage
Old 10-21-2016, 02:09 PM
MrFusion's Avatar
Originally Posted by BHD
I thought about it, but that isn't my style. I despise oil leaks and cobbled up repairs. If I wasn't doing as much work on the rest of the truck I may consider it, but for me "good enough never is".
Living in the Northern Pennsyltuckey Rust Belt I thought you'd embrace the onboard rust prevention system.
thrashingcows (10-21-2016)
Old 10-21-2016, 03:17 PM
BHD
BHD's Avatar
Ha. It actually the southern Pennsyltucky rust belt, and I try not to drive cars and trucks I make nice in the months that Penn DOT feels the need to coat the road with corrosion inducing garbage.
Old 10-21-2016, 06:14 PM
dodgenstein's Avatar
Cam does not have to be removed to change case. Use the proper puller and remove the gear. Heat in oven (do not use a torch or flame) to 350 degrees and it will slip back on. Use good welder gloves for this.
Old 10-22-2016, 09:33 AM
BHD
BHD's Avatar
My local Cummins shop had all the gaskets, dowel pin, and a used gear cover. So I spent a few hours swapping parts last night. I rolled the engine on its side to not have to mess with the tappets. A few hours of my time now is worth peace of mind down the road.
The following 2 users liked this post by BHD:
oliver foster (10-22-2016), patdaly (10-24-2016)
Old 10-22-2016, 10:03 AM
samiam4's Avatar
Good to see the invested time. Patching can work for a longtime, but with engine out.. good to see it right. Replace the gear too!!
Ideally, 275 in the oven is plenty. You can set it in a cast iron pan.
M
075point9
38
05-18-2013 12:03 AM
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
J.R. Adkins
06-16-2003 07:57 PM
Monty
06-09-2003 09:23 PM
Quick Reply: KDP carnage
