KDP carnage
Old Oct 19, 2016 | 10:21 PM
BHD's Avatar
BHD
KDP carnage
Working on my donor engine for my '74 Crew Cab tonight and when I pulled the front cover to replace the front seal and gasket I was dismayed to find the KDP was MIA.
And upon further inspection I found that it made a journey south, leaving behind a path of destruction.
The cracked case is easily seen in that pic. Oddly enough the engine didn't leak oil too badly.
Old Oct 19, 2016 | 10:27 PM
BHD's Avatar
BHD
What really has me concerned is the broken cam gear tooth.
This engine ran well and has no other issues. The IP was recently rebuilt before I bought it, no smoke, or odd noises. I do have a parts engine with, what I hope is a good case. Should I be concerned with the chipped cam gear or just let it ride?
Old Oct 19, 2016 | 11:29 PM
1320Fastback's Avatar
You have to pull the gears off to change the case don't you?
Old Oct 19, 2016 | 11:58 PM
BHD's Avatar
BHD
It's not that simple. The IP and vac pump have to be removed. Cam gear is a press fit, so cam has to come out, and the timing pin is supposed to be checked against true TDC on number 1 cylinder when the gear case is changed.
Old Oct 20, 2016 | 12:19 AM
Might as well change the gear then.
OR
Case really doesn't look like some of the other ones that had KDP damage. If it barely leaked I think I might try sealing it up and running it as is with same gear.
Old Oct 20, 2016 | 07:17 AM
Cummins now pulls the gear off the cam rather than pulling the cam to change out timing cases. Then they heat the gear up and press it back on the cam.
You could do it either way.
Or just seal up the crack in the cover and run it as is.
Old Oct 20, 2016 | 08:09 AM
patdaly's Avatar
Eh, if you have the engine out of the truck it isn't a big deal to pull the cam and fix it right.
Just keep engine upside down while cam is out or at the least on its side so tappets don't fall out.
Old Oct 20, 2016 | 10:09 AM
kensmachine's Avatar
that gear will run a long time like that it's most likely already run a long time. 3/4 or more is still there Ken
Old Oct 20, 2016 | 11:24 AM
BHD's Avatar
BHD
By the looks of the engine, it has been running quite a while like this. I can't see any marring on the crank or pump gear to warrant changing gears. I plan to attempt to dress it with a gear stone and reuse it.
Old Oct 20, 2016 | 11:28 AM
MrFusion's Avatar
I'd say the PO got VERY lucky that there wasn't more catastrophic damage.
Old Oct 21, 2016 | 12:12 PM
I agree witht eh others....just clean it up and run it. I wouldn't bother with replacing the case. I would probably clean the cracked area really well, the smear some RTV or some similar product on the inside of the case over the crack...then maybe some JB weld, or two part epoxy on the outside?
Old Oct 21, 2016 | 01:52 PM
MrFusion's Avatar
If the case was holed or the crack was worse I'd replace it. But with what you have I'd patch it like TC said.
Old Oct 21, 2016 | 01:58 PM
BHD's Avatar
BHD
I agree. I've heard stories of the KDP going the other way and wiping out the entire gear train, bending push rods and valve, and other such nonsense.
After seeing this mess, every other 5.9BT I own or work on will get the KDP tabbed or at least the hole in the gear cover staked so the pin can't exit.
Old Oct 21, 2016 | 02:00 PM
BHD's Avatar
BHD
I thought about it, but that isn't my style. I despise oil leaks and cobbled up repairs. If I wasn't doing as much work on the rest of the truck I may consider it, but for me "good enough never is".
Old Oct 21, 2016 | 02:07 PM
MrFusion's Avatar
KDP was the first thing I did to my truck. I scared myself silly reading catastrophic failure stories on the net.
