Daytime running lights
Old 01-03-2007, 01:56 PM
lgp9999's Avatar
It turns out that I have a Canadian truck, which means daytime running lights. Feel free to disagree, but this is something that I personally cannot stand! I am on a quest to disable them now. Has anybody else done this? When the parking brake is on the lights aren't, so I may check into disabling them in that manor.
Any other characteristics that the Canadian trucks got that the US trucks didn't?
Old 01-03-2007, 04:06 PM
Devin_01's Avatar
You can unplug the module on the front drivers fender well but the only problem with that is you wont have a high beam indicator. The lights will still work high and low beam just the indicator on the dash doesnt.
Old 01-03-2007, 05:23 PM
Sidewinder's Avatar
As mentioned you can unplug the module on the drivers side front fender. If you search hard enough you should be able to find a thread that explains how to put a jumper in somewhere to restore the highbeam indicator light on the dash.
Old 01-03-2007, 05:28 PM
lgp9999's Avatar
I may use this route as a last resort, but for now I'll look into making it think that the brake is on. I'm thinking that it may simply just ground a wire when the brake is on, so if I'll just make that wire grounded all the time. We'll see and I'll post what I find.
Old 01-04-2007, 07:06 AM
CTD NUT's Avatar
There is no sense in messing with the e brake to disable the DRL's (why anyone needs to disable them is beyond me....but to each his own, I suppose). A pic says a thousand words.....just disconnect the DRL module and do the jumper as shown in this pic.
Old 01-04-2007, 07:19 AM
04ctd's Avatar
i know the US trucks can have the DRL's enabled by the dealer, or disabled after being enabled.
i think the Triple Dog can do these features (and the delayed accessory power, high idle, other stuff)
Old 01-04-2007, 10:10 AM
lgp9999's Avatar
Okay, I'll do that. Easy enough. Thanks!
Old 01-04-2007, 10:18 AM
DeTree's Avatar
another way to do it is find the ground wire that feeds the drl module for the parking light and ground it. That way...the module is still plugged in and the light works for the hand brake. I too disabled mine as I seem to have a problem with control lol. Hope this helps
the Tree
Old 01-20-2007, 03:58 PM
lgp9999's Avatar
I just did this but the high beam indicator still doesn't work.
Old 01-21-2007, 02:51 PM
js
js's Avatar
my module died and i jumped the connectors and it works great. i have high beam light and no running lights.
Old 01-22-2007, 12:10 AM
lgp9999's Avatar
Hmm, weird. The DRLs don't work anymore, but neither does the high beam indicator light. I have it jumped as shown, with a good connection. I wonder if there was a change sometime between your '96 and my '98. There are only so many possibilities. I'll probably just try all of them until the high beam light works.
BuckyKatt
02-08-2013 01:12 PM
getrdun
11-26-2008 11:46 AM
canucktrucks
04-15-2004 09:38 PM
blownbanana
30
03-28-2004 12:41 PM
fitzer
01-18-2003 01:11 AM
Quick Reply: Daytime running lights
