daytime running lights
Guest
Posts: n/a
Question for fellow Canucks.(and Canadian trucks) Does anyone know how to disable the daytime running lights? Not that I will run without lights, it's just that it kind of defeats the purpose of fog lights if I run into a snowstorm or fog.
Re:daytime running lights
You can unplug the DRL module under the hood. I'm not sure exactly where it is (drivers side fender I think) The problem with "unplugging" the module is that your high beam indicator lights up and stays lit.<br>I've thought about the same situation with regards to using fogs only. Problem is that the factory fog lights suck when compared to a real "fog" type light. Not sure if you have already tried this but, find a dark straight road, turn on your fogs and put on park brake enough to turn of DRL's. You'll find they are not that great. If it's really important to have for foggy weather, buy a set of real fog lights from Hella, Bosch, Cibie, etc.<br><br>Just my .02 cents
Actually, if you unplug the module, you have NO high beam indicator light. That's the only problem. A plus is that the fog lights work on high beam and low beam. At least that's the way it was on my '97 gasser and the '02 CTD.
I went through 2 modules on the '97 and figured screw it the third time, just left it unplugged. When the module calves, your high beam light will remain on as will your headlights, draining the battery. So, as far as I'm concerned, they're useless.
Guest
Posts: n/a
Thanks for the replys. I have been clicking the brake one notch so far, I just thought if I could unhook the 'module', I would. I've got the parking brake set pretty tight, so I was just afraid if I missed the first notch, and went to the second, I make be dragging the brakes a bit. But, I'll just leave well enough alone, and be careful.
You might want to see if this is a feature you can enable or disable with the DRB. I know from experiance that you can disable the DRL feature on some of the newer models,but i don't know when they started this. If you hook up the DRB,go into "customers preferances" and see if it there to enable or disable. TGCTD
BuckyKatt
Feb 8, 2013 01:12 PM
getrdun
Nov 26, 2008 11:46 AM
CNYRAM
23
Apr 20, 2004 07:09 PM
blownbanana
30
Mar 28, 2004 12:41 PM
