Adjusting Headlight Beam?
Since I have my truck lifted a bit, everyone thinks that I have my brights on when I just have the lows on. Is there any way to adjust the beams on these new headlamp assemblies? I am getting tired of brighting people to explain that I AM on low beam!
ALL headlamps have adjustments. simply remove trim to locate.
assuming you don't have the high $$ beam alignment tools...
best way to aim headlamps is to find a dark level parking lot. back off 50feet or so, shine beam against wall to find aim points.
The adjuster is behind the little rubber seal on the headlight assembly. Pop the hood, fold the seal back, and use a T-15 Torx driver (I think, I can't remember exactly) to adjust. Well, thats how I did mine anyway!
Thanks Ptgarcia. I had a look and couldn't find the adjusters. It was too cold out here today to take an extended look around.
I have to adjust mine down a bit also, since I lowered the back end, I have gotten lots of high beams.
IPDiesel
12-16-2010 04:25 PM
tcb
25
12-20-2004 01:25 AM
