outside temp sensor??
Hey,
I have the overhead consol deal w/the temp, mpg, comp., and other stuff. Well the temp readings been all over from 44* F to about 140*F or so (currently 70-100). Is there a sensor or something I need to replace to fix this??? Thanks,
TNutcher
TNutcher
Clean the oxidation - disconnect the sensor, dip the connectors in CLR, then in water\baking soda to nuetralize the acid, blow-dry, dip connectors in Dexron III or other electrical insulative goop, reconnect.
Also check the female pins for snug fit to the male pins before you goop it up.
ppsi
10-13-2011 07:35 PM
MossyOakCTD
19
12-28-2010 09:11 PM
