outside temp sensor??
Old Jul 31, 2006 | 04:17 PM
TNutcher's Avatar
Hey,
I have the overhead consol deal w/the temp, mpg, comp., and other stuff. Well the temp readings been all over from 44* F to about 140*F or so (currently 70-100). Is there a sensor or something I need to replace to fix this??? Thanks,
TNutcher
Old Jul 31, 2006 | 06:48 PM
gmctd's Avatar
Clean the oxidation - disconnect the sensor, dip the connectors in CLR, then in water\baking soda to nuetralize the acid, blow-dry, dip connectors in Dexron III or other electrical insulative goop, reconnect.
Also check the female pins for snug fit to the male pins before you goop it up.
Old Aug 6, 2006 | 05:37 PM
TNutcher's Avatar
thanks. Where is this sensor located at?? Appriciate the advice
TNutcher
Old Aug 6, 2006 | 06:50 PM
VinDiesel's Avatar
On my '96, it's on the left front of the radiator support just above the bumper next to the headlight assembly.
Old Aug 6, 2006 | 07:11 PM
phox_mulder's Avatar
Pretty sure it's the same for a '99.
2000 or 2001 they moved to to the hood latch assembly, hood side.
phox
Old Aug 6, 2006 | 11:02 PM
TNutcher's Avatar
anyone have a pic. so i know kinda what to look for?? Thanks a million guys
TNutcher
ppsi
Oct 13, 2011 07:35 PM
MossyOakCTD
19
Dec 28, 2010 09:11 PM
mortis_9812v
Mar 21, 2007 09:36 PM
kingofdodge7131
Mar 8, 2006 10:17 PM
turbox2
Feb 6, 2006 07:44 PM
