outside temp sensor??
Hey,
I have the overhead consol deal w/the temp, mpg, comp., and other stuff. Well the temp readings been all over from 44* F to about 140*F or so (currently 70-100). Is there a sensor or something I need to replace to fix this??? Thanks, TNutcher |
Clean the oxidation - disconnect the sensor, dip the connectors in CLR, then in water\baking soda to nuetralize the acid, blow-dry, dip connectors in Dexron III or other electrical insulative goop, reconnect.
Also check the female pins for snug fit to the male pins before you goop it up. |
thanks. Where is this sensor located at?? Appriciate the advice :cool:
TNutcher |
On my '96, it's on the left front of the radiator support just above the bumper next to the headlight assembly.
Pretty sure it's the same for a '99.
2000 or 2001 they moved to to the hood latch assembly, hood side. phox |
anyone have a pic. so i know kinda what to look for?? Thanks a million guys
TNutcher |
