new starter wont crank
Old 08-23-2014, 04:23 PM
1991.5 mopar's Avatar
can someone tell me how to jump a starter? im doing a 47rh swap in 1991.5 and i need to run the truck before i put the trans in to check for leaks. couls the neutral safety switch not being plugged in cause it from not being able to start?
Old 08-23-2014, 04:46 PM
Jim5870's Avatar
run a wire from the small stud on the solenoid
to battery positive.
Old 08-30-2014, 09:50 AM
BearKiller's Avatar
What ^^^ he ^^^ said.
Also, if the starter-cable is still factory-original, there should be a BROWN wire routed along-side the big cable that terminates in a plug along with a PINK wire (I may not be remembering these colors correctly; it will be the only wire taped along the big cable).
This BROWN wire is attached to the small solenoid terminal on the starter.
Simply poke a short length of wire into the BROWN wire's side of the plug (at the top end near the battery) and touch this wire to battery-HOT --- preferably AWAY from the battery itself, like maybe a HOT grid-heater stud or some other HOT source.
Old 08-30-2014, 12:34 PM
Received 1,332 Likes on 862 Posts
Your PCM needs to see a ground signal from the neutral safety switch. The 3 pin, round plug that is part of the OEM wiring is the the neutral, reverse lights. Take a small piece of wire and insert it into the middle connection...that is the neutral ground. Then run the wire to the frame to ground it. The motor should now start as normal.
Old 08-30-2014, 02:29 PM
rrgrassi's Avatar
Will the engine run properly with the trnas not mounted? IIRC the T/C on an automatic adds to the weight needed on the flywheel.
Old 08-30-2014, 02:58 PM
I ran my 93 motor with no auto tranny in the donor truck. Didn't run it for very long, 5-10minutes, but ran fine with no additional vibration that I could discern.
Old 08-30-2014, 09:47 PM
j_martin's Avatar
That concern is a vestige of working with Mopar 360 engines vs 318 engines. The 360 automatic torque converter has a weight on it that is part of the crank balance. If you replace that 360 with a 318 and don't change the torque converter, it'll shake like crazy, and vice versa.
BTDT got the T-shirt.
jkarner
09-23-2010 03:51 PM
Mudskiff
11-15-2009 06:15 PM
smokin'04
05-09-2009 08:02 PM
buckman361
11-13-2008 09:54 AM
PaulDaisy
12-02-2006 12:36 PM
Quick Reply: new starter wont crank
