can you install a non i/c ve pump on an intercooled cummins
Well the simple answer is yes...BUT...there is a difference in the length of the delivery valves. The Non-IC DV's are longer then the IC DV's. So I doubt your lines would mount. Now you could swap over your IC DV's onto the Non-IC IP, or get a set of Non-IC fuel lines.
As for the KSB...why would you want to run without one? If you don't want it functioning then just disconnect the power source.
The individual pumps are the same...but the Non-IC delivery valves supply a bit more fuel to the bigger Non-IC injectors. As well the Non-IC IP is timed a bit steeper then the IC pump....1.4MM vs 1.25MM IIRC?
I just installed an ic pump on a non ic engine, n the lines were only a 1/2" shortm alittle bit of tweekin n they fit just fine. Wish I knew the non ic had bigger dv s
1985cucv
06-12-2009 09:50 PM
wannadiesel
03-31-2008 10:11 PM
sammy340
04-05-2005 03:55 PM
