windshield washer pump
Old Mar 28, 2009 | 12:17 AM
SNOWJUNKIE's Avatar
Hey guys. My truck came from the dealer with water in the washer fluid container instead of washer fluid so needless to say, it froze this winter Once I got it thawed out it worked for a few shots, then quit working. pulled the pump out and hot wired it, and it seems to work fine. Evidently there is no fuse, so, where do I go from here?
Old Mar 29, 2009 | 09:39 AM
megacabdad's Avatar
Sounds like you may have a restriction somewhere in a feeder tube...
Or a clogged nozzle.
Old Mar 29, 2009 | 09:41 AM
madhat's Avatar
Administrator/Jarhead
Is there power going to the plug?
Old Mar 29, 2009 | 11:53 PM
SNOWJUNKIE's Avatar
no power to plug, makes no sense to me why they wouln't put a stinkin fuse in it, maybe that was as hard for them as making a comfortable seat
Old Mar 30, 2009 | 11:03 PM
alMout's Avatar
I think the pump is controlled directly by the power module and should have a resettable breaker. You may try to unhook both batteries for a minute or two to see if it resets.
Old Mar 31, 2009 | 04:01 AM
madhat's Avatar
This is what I have for the power supply... You're checking the power when someone else is activating the washer motor, correct?
The washer pump/motor control circuit is energized
through a high side driver within the Front Control
Module (FCM) whenever the FCM receives an electronic
message requesting washer system operation
from the instrument cluster over the Programmable
Communications Interface (PCI) data bus. The
instrument cluster monitors a resistor multiplexed
hard wired input from the momentary washer switch
contacts within the multi-function switch on the
steering column to determine when it should issue
the electronic message requesting washer system
operation.
Old Apr 1, 2009 | 01:12 AM
SNOWJUNKIE's Avatar
Thanks alMout, I'll try that. Madhat, I don't think you realize the lack of grey matter I have to deal with on a daily basis or you might have dumbed down that paragraph a bit. Thanks for the info guys.
Old Apr 1, 2009 | 04:08 AM
madhat's Avatar
Ok, no, I understand... I deal with Marines all day... and I am one...
Get a multimeter or a test light. Stick the positive lead in the plug, and the ground on a good piece of metal on the truck. Have some one press the switch for the windshield washer fluid. Put the positive lead in the other hole. Did you get 12 volts in either of them? If yes, then replace the washer pump. (I can give you the details on that, too.)
If no, then you need to find the wire that controls the WW fluid pump coming from your column and see if it's putting power out. You may have to remove the cover on your steering column if you cannot locate it coming from underneath the kneeboard. There are 2 Torx head screws on the bottom, if I remember correctly. You'll have to pull the steering wheel tilt **** (if equipped) off... just pull it straight out, I think. Then, carefully seperate the two pieces. The dust cover for the shifter will come out too. The wire you are looking for is violet with a light green stripe that goes into your instrument cluster from the multifunction switch. Pin 8. This is the wire that sends the signal to the FCM. Pierce it and see if it has power when the switch is activated. If that's not it, then you may have a bad switch. If you do have power there, then you have to look to the FCM. That's were things get difficult...
If you test the stuff up there and still have no love, I would suggest getting the truck plugged into a DRBIII at the dealer and using that to trouble shoot it. The FCM is under the fuse box, or IPM, and I believe that it's just a printed circuit board. If you need me to, I can go deeper, but do the stuff up there first...
I hope that is a little more helpful.
Old Apr 1, 2009 | 11:29 PM
SNOWJUNKIE's Avatar
thanks madhat, I have no power at the plug with switch engaged and pump motor is good. I will check for power from the switch as instructed. you're the man for taking the time for such detailed instructions thanks again
Old Apr 4, 2009 | 08:09 AM
madhat's Avatar
No problem, brother. Let keep me posted.
APD
Dec 23, 2013 10:17 AM
06RAMCTD
Nov 28, 2009 07:57 AM
Larry R
Apr 24, 2006 08:42 AM
ptm600
Jan 31, 2006 07:43 PM
Igor
Nov 15, 2005 03:04 PM
