Winch mount design
Old 09-08-2003, 08:14 PM
rifleman's Avatar
Winch mount design
I have recently picked up my 2500 CTD HO SLT Sport. The Sport bumper, looks so good that I don't want to take it off. I was thinking of designing a bracket that will hold my Warn 12K winch that attaches to the mounting spots for the tow hooks. Does anyone have any concerns with this mounting position? Any alternate ideas?
Thanks,
Rob
Old 09-08-2003, 09:46 PM
DF5152's Avatar
Re:Winch mount design
been considering the same thing but just installed a warn light bar that goes there warn also make a front reciever that may or maynot fit. not sure if that mointing point would be all that strong when winching out ur truck from a good stuck.
Dan
if u come up with anything let me know
Old 09-09-2003, 10:05 AM
TON4FUN's Avatar
I would think the point where the hooks go is fine. I installed hooks on my other 03 and where the hooks bolt to is all frame. What else would you want to bolt to?
Old 09-09-2003, 02:19 PM
DF5152's Avatar
if i remember correctly the brackets that hold the hooks ar mounted to the frame where the bumper mounts. I would rather eliminate the tow hook brackets and go right to the frame 1 less place to have any problems especially when trying to winch an 8000lbs truck from a good stuck.
Dan
Old 09-10-2003, 12:48 PM
Steve034x4's Avatar
Location: North of the Frost Line....near Priddis Alberta
Rifleman, I used a Warn Trans4mer kit for mounting my 12000# winch (also Warn). The kit replaces the bumper support brackets (and thereby the hooks) with various pieces of steel superstructure and you drill/bolt to the front section of the frame directly. Lots of steel and Gr 5 bolts ... this is a pretty strong design. The kit is designed for up to a 15000# winch so it's no lightweight.
Personally I would hesitiate to rely on the relatively small bolts holes and thinner supporting steel that makes up the OEM hook and bumper support for a 12000# winch and get a kit that is designed for this.
Old 09-10-2003, 02:31 PM
RockMonkey's Avatar
[quote author=DF5152 link=board=17;threadid=19410;start=0#msg182273 date=1063075582]
[/quote]
Do you have any pics of this? I would like to add some extra lighting, but haven't really liked anything I've seen so far, was thinking about building something myself, but Warn usually does a pretty good job.
Old 09-10-2003, 04:48 PM
DF5152's Avatar
[quote author=RockMonkey link=board=17;threadid=19410;start=0#msg183167 date=1063222302]
[/quote]
[/quote]
The bar fits and looks nice. Ive had push bars and grill guards which become a hassle to clean around JMO. but this is simple and looks good. The only drawback i have noticed is it only comes one color an argent silver i had my powder coated black to match the truck. i'll post some photos later.
some photos
before
after
Old 09-10-2003, 06:14 PM
rifleman's Avatar
Steve034x4,
Do you have pics of the Trans4mer on your truck? I haven't seen any good pictures of this setup on a Dodge.
Thanks,
Rifleman
Old 09-15-2003, 12:05 PM
Steve034x4's Avatar
Sorry, Rifleman...I don't have a digital camera yet and no easy access to a scanner either. I'll try to find/borrow one and will post.
Pooter
36
09-03-2007 08:57 PM
Erik
19
01-16-2007 04:53 PM
runamuk
Off Road / 4x4
18
10-24-2005 10:08 AM
Igor
09-19-2005 03:17 PM
sshelly
08-28-2005 03:07 PM
Quick Reply: Winch mount design
