Why when its 40 below?
Old Mar 14, 2006 | 09:27 AM
'80Toad's Avatar
Morning folks!
I have a weird one. It sucks because its 40 below with the wind this morning.
I had to boost my truck to start it to get to work. I don't think I had it plugged in enough, I need one of the lighted cords. Let it warm up while I was in the shower. The grid heater had stopped cycling when I went to leave and all the gauges looked good. About halfway through my 10 minute drive the voltage goes to zero and when I park at work and try to restart the battery is seems dead. I have a charger on it now.
A few months ago I ripped the ECU out and send it away because of over charging. It checked out so I redid the connections and got it all working properly, or so it seemed. Think the two are related or has my alternator calved?
Corey
Old Mar 14, 2006 | 09:45 AM
infidel's Avatar
Sounds like bad batteries or connections.
Old Mar 14, 2006 | 09:54 AM
P.O.R.'s Avatar
in cold weather leave it plugged in all nite,or at least 6 - 8 hours to do any good.
Old Mar 14, 2006 | 11:20 AM
'80Toad's Avatar
I do generally leave it plugged in all night. And it starts awesome. I must have not plugged into the socket properly last night is all. Just happened to be -40 too.
Anyways, little update I called around and was able to get a into a shop today to look at (very rare to get same day service here). On the drive there it seems to be charging but the check engine light has come on. The only other time I've had the light come on is accidently overrevved the engine downshifting one time.
92 one ton with a 5 speed.
Corey
Old Mar 14, 2006 | 06:54 PM
Check the crank sensor and the wiring harness down to it. Gap between the sensor and the damper should be 0.050", check with a brass feeler gauge.
Old Mar 14, 2006 | 07:06 PM
Geico266's Avatar
Wind chill has no effect on metal. Ambient air temp is all that matters.
Old Mar 15, 2006 | 08:29 AM
'80Toad's Avatar
I know, but it affects me when I have to boost it and swap out the alternator.
Turns out the alternator went south. I guess it was just a weird coincidence it happened then. Could have been any day, but happened to be the coldest day of the year so far.
Thanks for all the suggestions!!
Corey
Old Mar 15, 2006 | 09:36 AM
infidel's Avatar
Wind chill has no effect on the ultimate minumum temp of metal but speeds the rate it gets there.
luke03cr
Jan 3, 2012 04:07 PM
southpawslingr1
Jul 9, 2008 08:44 PM
sgrooms
21
Apr 8, 2008 11:17 AM
bulabula
Aug 21, 2003 12:23 AM
DieselDaze
Jul 17, 2003 09:21 PM
