Which Vp44 would be good for me?
I am thinking the hotrod pump.
edge juice with att and 4 inch exhaust. will a hotrod pump work with this set up? and possible 275 injectors.
will this pump be good for alot of hauling?
truck has new APPS an new carter lift pump.
I too would be interested in what pump is the best since I think mine is gettig weak. I am beginning to think it is the root of my troubles. Does anyone rebuild the pump you send in for a cheaper price or do you just send in your old one for a core charge? It sure would be nice to know how to do it and just buy the rebuild kit for half the price of a new pump. I'm sure I could really screw that one up!
You might want to look into an SO pump for your truck. A HRVP is said to start to level out with an SO pump once you start tapping the wire and using bigger sticks. Its great without a wire tapping box though.
If you plan on or already have a wire tap box DO NOT waste your money on any type of HRVP. Save your hard earned money and buy and SO pump. It will work without any problems. There have been many who've done it with great success. You will loose a little low end grunt that the HO pump gives, but IMO I'll loose that little bit to keep some coin in my pocket.
Bradleysram
19
May 12, 2009 08:36 AM
SlowSixSpeed
Nov 22, 2007 04:15 PM
turbo hoss
Oct 21, 2007 02:19 PM
tthomass
20
Aug 19, 2005 09:35 PM
