Weirdest dang squeek
My truck makes a wierd squeeking/hydrauic leak sounding noise whenever I close the door or jump in and out of it- could it be a shock leaking somewhere? Anyone else have this happen?
Mine makes a squeek like that. I figured out that it is the rubber stop for the rear door on the bottom of the door jamb. It is located in the same unit as the catch. I haven't fixed it yet, so can't offer a solution. I'm thinking spray teflon lube would do the trick, though.
I'm not sure if this is the same exact squeek that you are experiencing, but I experience mine on rough rodes, when opening and closing the rear door, and sometimes when opening/closing the front door.
GasganoFJ60
10-11-2007 04:55 PM
Ken W
07-23-2004 05:24 PM
