Wastegate questions
Old 07-01-2007, 03:59 PM
JSPulliam21's Avatar
Wastegate questions
I can hit 30-32 psi with the mods listed in my sig. Is there a way to tell if my wastegate is disabled? I didn't think I was supposed to be able to boost that high. Is this normal, or is there something up with my wastegate?
Old 07-01-2007, 07:04 PM
clutch1's Avatar
with enough fuel you'll be able to out flow the wastgate even if it is disabled
Old 07-01-2007, 08:15 PM
HOHN's Avatar
I think you mean enabled.
Anyway, look for a pipe plug in the compressor's boost port to the wg actuation line.
jh
Old 07-01-2007, 10:01 PM
I have a stock boost elbow on it. I tried to push and pull on the rod from the actuator, and I could not get it to move. Should it?
Old 07-01-2007, 10:05 PM
1stGen545's Avatar
The spring is realy stiff. You are in good shape all the way to 36psi.
Old 07-02-2007, 12:04 AM
So, stock boost elbow and 30 psi with 75 hp nozzles is normal, and ok. Thanks!
Old 07-02-2007, 01:35 AM
HOHN's Avatar
The stock WG is set to to limit boost to around 20psi.
If you're getting 30psi, then someone has fiddled with your WG.
30psi is perfectly safe-- just not stock. When I had 75hp sticks with a stock WG, I could not exceed 20psi.
I think your "stock" boost elbow isn't stock at all
Old 07-02-2007, 06:08 AM
I know the boost elbow is stock, because it came off of a friends truck that was bone stock. He could not exceed about 20 psi with it. That is why I questioned the wastegate.
Old 07-02-2007, 10:13 AM
clutch1's Avatar
yeah i meant enabled, with mine enabled i could out flow the WG
Old 07-02-2007, 11:06 AM
DTR's 'Go to Guy'
vzdude's Avatar
The wastegate on those were very prone to lock up. Get a boost fooler and go with it!
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
boiler-rat
12-01-2004 06:57 PM
chadrock
19
07-14-2004 04:58 PM
Quick Reply: Wastegate questions
