tranny toast- will they replace.
Old 02-18-2010, 07:43 PM
crossy's Avatar
my 2005 had the last of the 7yr-70K warranty. the truck has only 60K and less then 7 years old so will they replace it w/o any cost to me.
i know these trannys were the reason they did away with the 7-70 in 2006.
Truck has never been in for ANYTHING before. any important TSB's or other things i should get done.
I guess i'll go to Price Dodge across the Del. bridge in New Castle , Delaware because i asked the question a while back if anyone knew a good dodge dealer within 50 miles of me and never got an answer.
thanx , crossy
Old 02-18-2010, 08:57 PM
cbrahs's Avatar
you better have proof of servicing the tranny at the correct intervals unless you have had them done at the dealership
Old 02-18-2010, 09:26 PM
1985cucv's Avatar
see if you qualify for the upgraded steering
Old 02-18-2010, 09:31 PM
cbrahs's Avatar
just wondering how the steering has anything to do with the tranny? plus they won't just toss on the upgraded steering for giggles.
Old 02-19-2010, 02:05 AM
Dr.Dizzle's Avatar
Hi crossy,
I have attached a link, if you wish to look up any information regarding recalls and TSB's associated with the vehicle. Once you get to the site, click on the "For Owners" area. At that point go to the "About my Vehicle" area and fill in the questions asked about your vehicle.
http://www.dodge.com
Old 02-19-2010, 12:51 PM
FunFinder5's Avatar
It would be very uncommon for them to replace it... Repair yes... replace, No. :-)
Old 02-19-2010, 12:53 PM
cbrahs's Avatar
they will if the replacement cost is cheaper than rebuild cost
Old 02-19-2010, 01:23 PM
Just a plain ole guy
1-2-3's Avatar
I would think they would run it down to a local transmission shop.
Old 02-19-2010, 01:34 PM
SuperGewl's Avatar
Have them run it down to local shop and then you pay the difference for upgraded parts to help make your tranny bulllet proof. You won't spend that much and will be much happier with the end results, as long as the tranny shop is any good.
Old 02-19-2010, 01:52 PM
cbrahs's Avatar
would be cool if it were possible but warranty don't work that way. if it were an aftermarket warranty he could get away with this but not factory warranty
Old 02-19-2010, 02:47 PM
Dr.Dizzle's Avatar
I agree!
Old 02-19-2010, 05:51 PM
1985cucv's Avatar
Quote from Crossy: Truck has never been in for ANYTHING before. any important TSB's or other things i should get done.
so yeah see if you qualify for the upgraded steering while your in there
Old 02-19-2010, 09:28 PM
hector's Avatar
You list you have minor mods.. Depends on the mods.Form what I've been reading on the boards. They could be a warranty killer
Old 02-19-2010, 09:55 PM
cbrahs's Avatar
technical service bulletin is just that. it aids the techs for repairing an issue it is not a recall. they won't replace the linkage unless there is an issue with excessive wear.
desertram800
17
02-23-2007 02:54 PM
dieselfuelonly
02-11-2007 12:46 PM
blcoonrod
16
01-27-2007 05:20 PM
A-Poc
09-23-2005 04:31 PM
Quick Reply: tranny toast- will they replace.
