toyo open country m/t
Old 12-15-2008, 11:35 AM
cmonster's Avatar
I'm considering running toyo open country m/t's on my 2006 2500 quad cab. It currently has 285 70 17 bfg all terrains but the tires just look a little too small for the truck. I found that toyo makes a 285-75-17 open country which measures 34.1x11.6 according to their spec page. My question is whether or not the tires will rub at all with the 2 inch kit. I can't seem to get a straight answer from the tire shops but one thing I know is that I hate a rubbing tire. Has anyone ran this combo? Also will a 35 inch tire clear adequately if I went with a 3 inch kit? Many thanks.
Old 12-15-2008, 12:09 PM
silverrhino's Avatar
It all depends on the wheel combo. I have a 3" lift on mine and run 37's. Only rubbing I have is at full lock on the control arms. A wider wheel with near stock spec back spacing should get you set up good with no rubbing issues.
Old 12-15-2008, 02:36 PM
Howy's Avatar
I just bought that exact tire. I love it! I've been out in the Black Hills a lot lately for hunting and its muddy and snowy. These tires never let me down!! No rubbing issues at all. They do hum a little once above 50mph and drop the rpms down a little. Check out my pics below. Unless you have some wheels that stick way out you shouldn't have any problems.
Have a good one.
Old 12-15-2008, 02:50 PM
shineboy2's Avatar
Howy - is your truck leveled?
Old 12-15-2008, 07:44 PM
06dodgedrw's Avatar
i know with 37's they say on the sport they will rub on the front bottom corner of the bumper. Is there a way to space out the front bumper an inch or so, that way they wont rub? also if you run them on a dually i noticed that even with aftermarket rims there is no change with back spacing from stock just rim width, is there a way to make them not rub or atleast rub less?
Old 12-15-2008, 08:01 PM
Danderson's Avatar
I've got the AT version in the same size. Great tire and no rub issues.
ducktape
18
03-18-2006 07:07 PM
Dr.Kayak
0
08-22-2005 05:57 PM
jlells01
05-02-2005 11:56 PM
Fummins
02-15-2005 08:31 AM
HOHN
07-22-2004 10:13 AM
Quick Reply: toyo open country m/t
