A couple of Pics of My New Frontend
If your projectors are HID's then we have the same ones. Front looks very good.
Do you know what type of resistor was used and where it was placed to get the HID's to operate properly???
Sorry lamps aren't HID so no resistor.
The grill came painted to match and was perfect fit and match.
There's been a few write ups on these lamps, they are a plug and play except for the Halo's and LED's which I wired into my park lamps. The projector low beams have a nice cutoff point once you get them aligned. Same goes for the fogs, wired into the park lamp circuit for halo's. Projector's for the fogs is also really good, you can see the cutoff line of light is parallel with the road. Everything was bolt in and came out looking pretty cool, I was hoping it wouldn't look to "ricer-ish". On a side note I've hated the stock headlamp light output from day one, and these headlights finally do the job as far as lighting up the road.
Link for grill
http://cgi.ebay.ca/02-03-04-05-DODGE...QQcmdZViewItem
Can someone make me an avatar of the top pic? I hate resizing, they always come out too small.
The avitar max size is 65x65 pixels, I attached a file that is 65x49 pixels and under the size limit. It looks tiny, some other forums I frequent allow 100x100 pixels.
