Totally, Completely......Absolutely, 100% without a doubt........
Old Feb 12, 2008 | 02:22 AM
1-5-3-6-2-4's Avatar
just wasted the headgasket.
It may as well be a hound dog with its tongue hanging out.
It was my 1st official, for real tromp on the truck with the Adrenaline. Wasn't even flat out yet, 3/4 throttle, didn't see the boost display but maybe saw a 60 flash, was too busy trying to keep it straight in the middle of Deerfoot. coated the entire engine compartment.
Old Feb 12, 2008 | 03:27 AM
Tate's Avatar
Just spewing coolant, or oil too? You did pretty good with twins though, surprised it made it this long to be honest.
I've got a cometic gasket in the basement thats calling your name.
Old Feb 12, 2008 | 09:38 AM
I didn't see any coolant........there was too much oil on everything to even see what color parts were. The gasket wasted at the very front edge of the head.
cometic you say.......can you/I use that with o-rings? or is it meant to be without? being a stacked steel type?
Old Feb 12, 2008 | 11:13 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Dude...you better get rid of that black cloud over your truck.I'm going to check out the new PA on the south side.I will call you and stop by..
Old Feb 12, 2008 | 11:33 AM
cool ok, I have to meet the tow driver sometime to move my truck, not sure what time.
Old Feb 12, 2008 | 12:56 PM
Tate's Avatar
Cometic is supposed to be an alternative to o-rings, but hasn't proved to successful. I've been meaning to call cometic to return it, but have been lazy, and am guessing they won't take it back after about 4 months. But if you want to give it a shot, let me know.
Old Feb 12, 2008 | 01:00 PM
thanks but no, Aaron @ CT is getting my head to work over. I';ll use a thick Cummins gasket.
Old Feb 12, 2008 | 04:38 PM
Mike Holmen's Avatar
The Guru
You have to wait and see what those injectors really have left for ya? I got that old HX-40 of your apart. The turbine housing will fit right on my new HX-40's that I got. So I might have to break one in prior to running the garrett. That turbine bearing was shot. It will make a good spare parts turbo. What kinda of egt's did you see?
Old Feb 12, 2008 | 04:47 PM
not too too high with those on IIRC........
I believe this truck will be edited by admin retarded once all the boost and fuel stay in the hole........
Old Feb 12, 2008 | 05:02 PM
The Guru
You using a new head or using you're old one? I know Peak has a 24v fresh sitting in the their shop. The head gasket isn't to difficult of a job, you just have to get the block in decent shape. I was sizing up putting on a new 24v head that I've found at peak performance but still needs some extra stuff for me. Heavy springs (4000+ rpms springs, titinum retainers) and ports are hogged out to the max. So its on my wish list. I still have a sweet 24v stock core on my bench if you want a head. It has to be cleaned up abit. I must crazy I just bought a gearbox cover for a 12v engine.
Old Feb 12, 2008 | 10:24 PM
Tate's Avatar
Thats going to be my plan when its time for it to be done. Hopefully this summer, but that has been a phrase I've uttered numerous other times as well.
Old Feb 12, 2008 | 10:32 PM
maybe tommorrow I'll call Peak as well for a competitive price check.........
Old Feb 13, 2008 | 10:05 AM
The Guru
You can use my head and get it o-ringed. Leave your's together until you get the head back or when time premits. I Just need a core as using mine for mock on twins, so it doesn't have to be any good of a core. You just clean the old head prior to dropping it off. Its an option, as the valves aren't sunk and I can't see any cracks. I personnel rather have a new head, as they are a lot cheaper than you think to buy new. The head casting are really bad regardless which way you go. If you driven your truck hard (high coolant temps and high egt's) your valves and seats might be in rough shape. Get the head decked and have the machine shop document how much material they shave off. You might have to get a custom head gasket. If you had the time, and money, you could deck the block and get it true and straight. Old high mileage blocks are prone to wrappage. I'm planning on machining the block during the engine overhaul that I'm planning. As far as I know, no body has a decking plate for these motors. You could get one built but its will cost an arm.
Old Feb 13, 2008 | 12:41 PM
Hey Mike thats awesome, I think I'll take you up on that. I'll send that one to CT get it cut and when its done do the R&R all at once. I'll bring you the Vp core back to from Jay. I'll give you a call.
Old Feb 13, 2008 | 12:50 PM
dodgediesel's Avatar
Tate, are you trying to pawn that Cometic head gasket off on one of the boys??? Demon, my next motor work will be done by CT. The boys at PDR did a great job but shipping to BC was expensive and they took way too long. Aaron is minutes away and is a good guy. How much is he charging you for everything??
