Torque Convertor Drain
Old 02-06-2010, 01:09 PM
driftingfly's Avatar
When changing the transmission fluid on the 04.5 is there a drain plug for the torque convertor. Also, I see the TSB for the Governor Pressure Solenoid Valve, as discussed in other threads, where can this be purchased other than the dealer. Dealer price here for part # 04617210 is $144.00.
Thank you.
http://www.dodgeram.info/tsb/2007/21-009-07.htm
https://www.dieseltruckresource.com/...t229203p2.html
https://www.dieseltruckresource.com/...b-t226127.html
Old 02-06-2010, 03:11 PM
no_6_oh_no's Avatar
No drain plug for the TC, most just pull the rear cooler line and route it into a contanier. Run in neutral until flow drops, fill trans and repeat until fluid looks good.
OEM solenoid, transducer there also:
http://www.transmissionpartsusa.com/...-000053396.htm
Upgrade:
http://www.transmissioncenter.net/dodge.htm
Old 02-06-2010, 08:24 PM
Which line is the rear cooler line? Is this the hard line on the driver side about 6 inches above the pan?
Old 02-06-2010, 08:33 PM
no_6_oh_no's Avatar
Both the cooler lines are hard lines. You will have one at the front which is the cooler output and one at the rear of the main case which is the return. They are both right above the pan rail on the drivers side.
Old 02-06-2010, 08:39 PM
Thank you. Do you know the torque setting on the pan bolts. I found in a TSB that they were 13.6 Nm (125 in. lbs.), does that sound correct?
Old 02-06-2010, 08:41 PM
no_6_oh_no's Avatar
Not offhand, I just snug them until it feels right.
Old 02-06-2010, 09:31 PM
Got'er done.
Time to go watch the earlier recorded Bud Shootout.
Thanks again.
Old 02-07-2010, 09:35 PM
sotex's Avatar
solenoid fix
no 6 oh no. is there a part no . would like to order from transmisonpartsusa.sotex
Old 02-07-2010, 09:53 PM
no_6_oh_no's Avatar
The link in post #2 will take you to the part and the part number is there in the description. Is that what you mean?
93dieselZak
06-16-2011 06:10 PM
SnowRider1
11-19-2009 10:28 AM
J BODY
02-10-2004 11:50 PM
turbospl311
46
01-18-2003 06:36 AM
RickCJ
12-15-2002 06:04 PM
Quick Reply: Torque Convertor Drain
