Too much trans fliud
Need help,Is there a way to remove some trasmission fliud without removing the pan.The dip stick shows the fliud level pass the word MAX on the stick.I need to bring it down.Thanks in advance for any sugestions.
no, it is not.
go to northern tool, they have a MityVac Siphon for $15.
i would recommend getting it out ASAP.
I overfilled mine, and it started doing the stuttuttuuuttuuuuttterrreer shift,
and i pulled some out, but it still stuutututers.
Its fine, don't worry unless your seeing fluid coming out the breather and onto the ground under the truck. You can run the trans 1-2 quarts over full depending on how the stick is marked and its a good thing. Extra fluid is always a plus.
The fliud level goes past the word MAX up to the loop bend on the dip stick.The manual states not to overfill the trans because it will shorten its lifespan.I dont want to bring it back to the dodge dealer because they are the ones who overfill it.I will never go there again.If I can do it myself,thats what I will do.Its a shame that you can not trust the Dodge dealers,I have had too many bad experiances with them.But I will be force to use them on warranty work only.
Been there, done that, have the t-shirt
A big syringe (Auto parts/motorsports stores have them for mixing 2-stroke oil) and some clear plastic tubing (available at a hardware store) is the cheapest and easiest solution I found. Just suck it out the dipstick tube.
jjrightmire1973
Nov 20, 2008 08:20 AM
doubledodge2003
Feb 20, 2005 01:48 PM
