time delay in speed control
Old 10-27-2009, 07:02 PM
mt72916's Avatar
Cool time delay in speed control
I have this nagging but not serious problem with my speed contol system. When i hit the engage or resume type buttons there is about a 4 second delay before the speed control takes over. The delay makes me think did it not engage. Is this normal or do all the trucks do this? does anyone have any suggestions on how to fix this?
thanks
Old 10-28-2009, 07:12 AM
Steve Roseman's Avatar
How well does it maintain speed once set?
Old 10-28-2009, 07:52 AM
torqmonster's Avatar
I have the same problem, and once it is set it does drop off over time - it slowly slows down...
Old 10-28-2009, 10:03 AM
infidel's Avatar
Check if the hose going to the throttle actuator under the driver's side battery has an acid caused leak.
If there is a slight leak it will cause the cruise to be slow, bigger leak and it won't work at all, even bigger leak and your 4wd and climate controls won't work.
Old 10-28-2009, 09:46 PM
nickg's Avatar
mine engauges almost instantly, I second Bill's suggestion
Landini1
03-06-2009 07:01 PM
Steve-oh
07-14-2007 07:38 PM
USMC64-70
12-23-2004 08:27 AM
Jack Thorpe
11-06-2003 01:25 PM
Quick Reply: time delay in speed control
