throttle linkage
Old Apr 15, 2010 | 06:29 PM
1st gen wontabe's Avatar
throttle linkage
where can I buy the ball lock for the ends of the throttle linkage? The local cummins shop don't have them,nor the part stores including napa. Thanks,
Old Apr 15, 2010 | 06:30 PM
Did you give the Cummins dealer the part number from the sticky?
Old Apr 15, 2010 | 08:02 PM
Sorry,I didn't think of looking there.Thanks that was easy
Old Apr 15, 2010 | 08:24 PM
getstucksome's Avatar
dodge has them also. Just picked up the whole assembly for 36 bucks or so
Old Apr 15, 2010 | 09:45 PM
PapeCAT's Avatar
I bought the metal ones from cummins... great upgrade.
Old Apr 16, 2010 | 02:16 PM
Benjamin b2's Avatar
napa sells heim joints, so does motion, combined with 1/4" ready rod and it makes for a way tighter setup than the original plastic dodge garbage.
Old Apr 16, 2010 | 06:42 PM
PapeCAT's Avatar
indeed... very resourceful information. thanks
Old Apr 17, 2010 | 03:38 AM
Jim Lane's Avatar
Here is how I fixed mine; I replaced the plastic ones using steel Heim joints I got from my local Specialty Fastener supply.
I got both the Left and Right hand thread so I could use my factory threaded rod, All of the hardware is metric.
If you look you can see a groove around the end of the threaded portion of the right side joint, this signifies it has the left hand thread.
With this setup there is ZERO slack in my throttle.
A drop of oil on the joints ocasionally keeps everything running smoothe.
Jim
cLAYH
Feb 6, 2004 10:59 AM
db
Sep 25, 2003 10:41 AM
gunracer1
Aug 24, 2003 07:30 PM
soundfetish
Feb 5, 2003 04:06 PM
