Tach!
Old 01-20-2010, 01:40 PM
petrecca8's Avatar
Tach!
Ok so i bought a tach for my truck. Not really sure where to hook the green wire up. i know where to do my ground and power and such but not the one for actual RPMs oh and it an automatic. so how would i do that?
Old 01-20-2010, 01:59 PM
raggmann's Avatar
Is it a factory tach?
If so,there should be a 3 wire plug (black plastic) on the left side of the steering column between the column and the headlight switch, just hanging there in mid air.
It may help to take off the fuse block panel under the column to find the plug in.
Hope that helps.
Old 01-20-2010, 02:03 PM
petrecca8's Avatar
na its not factory and i just went and looked and there are two things i think it could be. there is a balck wire clip thing hooked up onto the hood latch under the dash and then there is 4 wires hanging down one red two white and a black wrapped in electrical tape either one of these??
Old 01-20-2010, 02:20 PM
dodgetrucker75's Avatar
if its not a factory tach, i dont think you are going to get it to work unless you buy an adapter, i have a dakota digital tach adapter in my 75 to run my autometer gauge, works very well, about $100 on ebay
Old 01-20-2010, 02:21 PM
unixcowboy's Avatar
Actually it's a 4 wire plug...
+12
Ground
Panel Light
Signal
I'd suspect the 4 wires hanging loose...
IF it is, then :
With the key OFF the black should be ground;
With the key ON the red should be +12;
IF these are what is listed above then with the key OFF turn on your park lights and one of the white wires should be hot - that's your light.
The remaining white wire will be the tach signal from the PCM.
Hope this helps get your tach working.
Old 01-20-2010, 03:04 PM
raggmann's Avatar
+12
Ground
Panel Light
Signal
IF it is, then :
Yeah,what unix says.
I don't have my truck here and for some reason Iforgot about the "light" wire.
Old 01-20-2010, 09:27 PM
921stgen's Avatar
What model of tach is it?
danlit
03-20-2003 06:29 PM
poolboy
12-18-2002 08:00 AM
cuminzd
11-13-2002 01:56 AM
1stGenBikeHauler
11-01-2002 10:27 AM
hellotbone
10-11-2002 04:04 PM
Quick Reply: Tach!
