Stock turbo
Stock turbo
Im building about 50 lbs of boost on the interstate with my stock turbo. Is this normal? My edge says im building average 39.2 lbs. Max 51.2 lbs. In all this i have terrible lag especailly when im towing. I tow small equipment around and im running everything on the recommended towing setting.
Ok i did that, and it didnt help much. I took her out for a spin on a long backroad real quick building around 35 lbs. and when i got on the main road, lag! Could it be the gasket?
Well kinda, When i step on the pedal i get response and alot of it. When i let my foot off the pedal i have a ton of lag mostly when i run on my highest power setting or im towing.
Sounds like you are barking the Turbo.. When you have boost high you do not want to let off quickly or the boost has no where to go but backwards where it came from. I have never seen anyone hurt a turbo from this but have been told it is possible.
Lag is when you step on the accelerator and it takes X-seconds before the truck makes boost and takes off.. Lag=delay
jaconst
Aug 16, 2014 11:00 AM
D45
Aug 11, 2008 12:26 AM
jgiachino
May 12, 2008 02:06 AM
Robert P
23
Mar 1, 2007 12:21 PM
Lark
18
Feb 12, 2007 06:34 PM
