What is stock Idle speed?
Old Sep 11, 2009 | 10:54 AM
schamran's Avatar
So What is stock idle speed? I will be turning up my fuel screw, and I will need to reset my idle with the optical tach at school.
Old Sep 11, 2009 | 11:55 AM
Ronny Bailey's Avatar
My Chilton's says:
With motor warmed up and AC on, 750 rpm. Auto trans, 700 rpm.
Old Sep 11, 2009 | 12:06 PM
Rick 12v CTD's Avatar
the plate on my timing case says 800 rpm. Anything from 650-800 is probably fine. Whatever you prefer. 650 rpm would probably make the truck shake and rattle a lot though
Old Sep 11, 2009 | 04:14 PM
I like 800 - 850 on a stick truck. Keeps the mirrors from shaking.
Old Sep 11, 2009 | 04:51 PM
RollinCoalSmoke's Avatar
If you like the way it idles now use the point and shoot tach before you tune on it. That way you have a base line to work with.
Old Sep 11, 2009 | 06:43 PM
dzl_damon's Avatar
Stick is nice, it doesn't matter as much. I had mine on the Utility truck up at 1100 after I turned up the fuel screw and it was PUSHING hard when I was stopped. I'm sure it heats up the fluid quick too. 800 now and it sounds very nice idling.
Old Sep 11, 2009 | 11:03 PM
Riflemanusmc's Avatar
Registered user
Mines at 750 with a phototach. Sounds high to me, but starts off good with the 5 speed.
dnrhorst
May 2, 2008 03:47 PM
faster_than_ford
33
Mar 5, 2004 07:24 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
