Steering pump issues...
Old 12-14-2006, 11:19 AM
89dieselkong's Avatar
I pulled into work the other and noticed my power steering pump was leaking from the bottom. Then I noticed one of those oval canister things that attach to the bottom and side of the pump. The bottom one broke off and was hanging. 2 of the screws sheared off so for a temporary fix I had to put one of the bolts in and JB weld the other side. It still leaks but is on there pretty good. The problem I have now is that the steering feels a little looser than before, and every once in awhile the wheel sticks. Then it snaps back to normal. What exactly are those cylinders? Is it time for a new pump maybe??
Old 12-14-2006, 11:24 AM
Those are the diaphragms for the vacuum pump, they have noting to do with the steering.
Old 12-14-2006, 11:52 AM
Should I be concerned that one of them is leaking?
Old 12-14-2006, 02:09 PM
loch's Avatar
vacuhm controls heater/ac as well as the power brakes.
Old 12-14-2006, 03:13 PM
Only if oil leaks bother you.
tony99
04-09-2014 08:25 AM
92smokin blacky
03-10-2011 09:30 AM
92smokin blacky
03-30-2010 06:09 PM
mstep3
01-18-2009 05:52 PM
DodgeCowboy
08-28-2006 08:57 PM
Quick Reply: Steering pump issues...
