Squeek Fix
Old 12-23-2006, 12:12 AM
gcajnr21's Avatar
Squeek Fix
Can anyone please post a pic or drawing of the steering parts that cause the squeeks and were they need to have lithium grease applied. Thanks guys
Old 12-23-2006, 08:57 AM
waldersha's Avatar
Can you give us some help with what year of truck you are talking about and other pertinent information? Like 2 or 4 wheel drive? Is the squeek when going over bumps or turning the wheels? If you will do that I'm sure that we can help you out.
Old 12-23-2006, 09:10 AM
gcajnr21's Avatar
im sorry i thought The sqeek from the Steering was a common issue. There have been several other post about this problem, but ive yet to see pics of were to exactly apply the lithium grease to fix the problem!
My truck is a 2nd gen. '01 2500 4x4, extcab, white with gray interior,disc brakes,pw windows and locks.
Old 12-23-2006, 09:38 AM
gcajnr21's Avatar
Okay i guess the squeek is from the linkage from my auto tranny. Pics would be great for anyone who needs a visual of were to spray lubrication
thanks guys
Old 12-23-2006, 09:44 AM
yfz450guy's Avatar
fill in your sig. so we know what year, make, model rig you have. not all rams ae the same. for all we know you are asking about a ford.
Old 12-23-2006, 10:07 AM
Sea Bass's Avatar
Well, there are a couple of squeaks you possibly have. I have two different ones. One is the linkage squeak that is actualy under your truck. But, I have one in my steering column that only squeaks when I'm turned slightly in one direction or the other and going over small bumps. That's the one I hate. I pretty sure that's from the bushing in the column itself.
Old 12-23-2006, 10:45 AM
sluggo42's Avatar
My truck is a 2000, and it has a mystery squeek that drives me nuts. It only does it while moving, but isn't in the wheels.
Old 12-25-2006, 11:14 PM
MARKY MARK's Avatar
I had a squeek and it was driving me nuts because I couldn't locate it. Then someone on this forum told me to look at the top of the fuel tank. The tank was just barely rubbing on the bottom of the bed or the cab...can't remember which one now. I sprayed some lithium grease where it was contacting and I haven't heard a peep out of it since. Just a thought.
Mark
Old 01-16-2007, 08:54 PM
dhvaughan's Avatar
i had a nasty squeak from the auto trans linkage that drove me crazy for months. there is a horizontal rod that connects the up/down linkage to the front/back linkage. it has plastic/nylon bushings on each end. mine would sort of rattle when you shut the drivers door and it would squeak whenever the truck was moving. whenever i got out and tried to find it, and there was no body motion, it would be silent. i found it one day when i had the hood about half way up and sort of twisted the hood and rocked the truck. had the wife rock it while i smeared grease all over the bushings and it shut up.
Old 01-17-2007, 07:59 PM
Ram1999's Avatar
Squeek Fix = Remove muffler, turn up the music, done.
04 Diesel
35
09-08-2009 08:43 PM
Txwelder
06-03-2005 07:34 PM
Ken W
07-23-2004 05:24 PM
kyle@ftlb
21
10-10-2003 06:45 PM
DuallyJeff
04-23-2003 09:01 PM
Quick Reply: Squeek Fix
