speedometer and odometer not working
Old May 19, 2012 | 09:11 PM
Exekiel69's Avatar
Worked some more on the 92 today, I pulled the dash and got a look at the speedometer, it does not have gears inside but a electric motor that turns the odometer and another one that turns the speedometer but looks like a clock. I pulled out everything I could and cleaned the electric pins, etc. Now when I put the key on the run position the needle goes straight to 25mph and no mater how fast I go when I drive it will stay right there.
I also pulled the gear at the transfer case cleaned it and put it back together, it all looked fine and all turned just fine. I followed the wires going to this sensor and the one on top of the TC back to the main harness, the wires look fine with no cuts visible.
I'm a bit lost as to what to do now to get this to work right. Thanks for any help.
Also on an unrelated note after I put a paper clip on the tranny temp sensor it feels like it does shift to OD now.
Old May 20, 2012 | 07:37 AM
Exekiel69's Avatar
Any guesses?
Old May 20, 2012 | 08:05 PM
Exekiel69's Avatar
Shall I assume this is a cluster for 93 dodges? I has no gears on it but it all looks stock.
Sleigher
May 4, 2017 02:12 PM
Darrin F.
Jun 14, 2012 08:10 AM
spitzair
Aug 28, 2006 01:25 PM
Mosh
May 28, 2006 06:41 AM
mytrucksaslug
May 26, 2006 10:00 AM
