slow 02 with edge comp?
Old 04-01-2006, 04:13 PM
ctdinwyo's Avatar
well I have an 02 that I put a comp on in ez mode and it seems to be slower than without, but it still puffs some smoke when i get on it, Also it runs great after 50 mph. Now let me tell u, the box is for an 01, so I just put an 01 map sensor in my truck and had a diesel shop make me the appropriate harness. I have been told the only differences in the map sensor are the plug design, So the only thing I can think of is that the made harness connections are not soldered together but twisted and taped, If thats not the problem what else could it be?
Old 04-01-2006, 05:09 PM
caper's Avatar
I got a comp in EZ on my 02 and ya can tell a difference , What sub level are ya useing ??? If your on sublevel 1or2 you wont feel anything till late in the rpm range. Sublevel 3-4 -5 youll feel it right away.
Old 04-01-2006, 08:58 PM
ctdinwyo's Avatar
Well since its in ez mode I left the levels at 1 on both. The truck just falls on its face at 2500 and it just feels like a dog. But when I hit 50 or the truck pulls pretty nicely because it stays at a lower rpm. I guess it just isnt what I expected to be
Old 04-01-2006, 09:09 PM
charles goss's Avatar
my father inlaw has 00 huge response also is the fuel turned up on the box hold the power level botton 5 seconds let off tell flashing to see if all bars are flashing you can go to edge wed page to get info or call me 480-332-7343
Old 04-01-2006, 09:10 PM
singleturnout's Avatar
whats the ez on the comp is it 1/1 iam sorry if this is a stupid ?
Old 04-01-2006, 10:51 PM
ctdinwyo's Avatar
yeah i think the ez setting is 1x1 but I here u get a little more throttle response at with the sub setting on 3.
but i cant believe that this truck isnt that much better 0-50
Old 04-02-2006, 04:01 AM
oestreich84's Avatar
Is your truck an automatic? If it is, I think the computer will defuel between shifts to save the tranny. That could be why it seems slower.
Old 04-02-2006, 07:57 AM
Administrator / Scooter Bum
Shovelhead's Avatar
If you're running it in the EZ mode, turn it up to level 5X5.
The timing will come in sooner, as it uses the "smoke level" settings to add timing too.
Old 04-02-2006, 04:37 PM
ctdinwyo's Avatar
well i moved the ground to the battery and it seemed to help a bit but the defueling seems to start so early and it doesnt have enough time to make power. I dont know it just irritates me because stock the acceleration from a stop seemed to be just as fast because the engine is working through the whole rpm band.
13jy831
02-25-2011 07:45 AM
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
Quick Reply: slow 02 with edge comp?
