should the fan be running when the engine is cold?
Old 12-15-2003, 07:42 AM
wood_n_soldier's Avatar
I was out scraping my windows this morning and noticed that the fan was on. should it be running when the engine is cold?
Old 12-15-2003, 12:56 PM
Alan_Reagan's Avatar
Re:should the fan be running when the engine is cold?
That's normal. The fan never stops spinning unless the engine is shut down. Mine roars until third gear and then releases on cold mornings. As long as it releases and quietens down after you start going up through the gears, it is normal.
Old 12-15-2003, 02:59 PM
Marine's Avatar
The only way to stop it is to take the fan off, or get a Horton.
Mike
Old 12-16-2003, 09:31 PM
dcwm's Avatar
Now I thought the fan would mysteriously come on when needed according to temperature, by use of a clutch. I know when it's hot out and I'm pulling a load the fan will come on with authority, run for a while until the temp decreases, shut off, come back on etc. It will cycle on and off or if it's hot enough it will stay on.
BTW Marine....our trucks could be twins....see sig below.
Old 12-17-2003, 11:29 AM
Marine's Avatar
Yours looks alot PRETTIER than mine does!
The fan is on all the time, but the fan clutch determines how fast it will spin according to the temp.
Mike
Old 12-19-2003, 04:47 PM
jigdog's Avatar
marine whats a horton ? electric?
Old 12-19-2003, 09:14 PM
Marine's Avatar
[quote author=jigdog link=board=4;threadid=23746;start=0#msg226542 date=1071874048]
[/quote]
It's electromagnetic. http://www.hortoninc.com/products/products.asp
It is on my wish list.
Mike
Old 12-20-2003, 12:47 AM
jigdog's Avatar
mike i think its on my wish list now too ;D
Old 12-20-2003, 12:01 PM
Marine's Avatar
[quote author=jigdog link=board=4;threadid=23746;start=0#msg226758 date=1071902861]
[/quote]
;D
Mike
Old 12-24-2003, 01:00 PM
thumper 549's Avatar
I left my fan off at rebuild been from here to the east coast over the passes several times (I watch it close) been about 4 months now...been towing about 10,000 lbs. So far no fan required.
92smokin blacky
10-07-2011 03:08 PM
black&blue
02-18-2009 08:32 PM
getblown5.9
03-23-2007 10:58 AM
big jimmy
07-07-2006 01:33 PM
wood_n_soldier
12-16-2003 07:07 AM
Quick Reply: should the fan be running when the engine is cold?
