shifter removal tool
Old 07-23-2006, 12:37 PM
realtreehunter's Avatar
anyone know where to get the tool to remove the shifter for the nv4500
Old 07-23-2006, 01:53 PM
robert chilton's Avatar
For the early style trans all you need is a hammer and screwdriver. Once the shifter boot is out of the way take a look at the cup on the inside of the shifter tower (the shifter goes through it). You will notice that there is a slight corner on four sides. Hook a corner of it with a screwdriver and hit down and counter clockwise to remove the shifter. The opposite to reinstall it. On the install it may be easier to have a friend holding the ring down while you hit it with a hammer.
Old 09-27-2006, 12:34 PM
RenegadeT's Avatar
Does my 98 12V have an 'early' style NV4500?
Old 09-27-2006, 09:31 PM
farmer0_1's Avatar
i just took my brothers 97 apart and it was as described. just a tap and a twist. took longer to get all the shift boot stuff out of the way.
Old 10-03-2006, 10:06 PM
mx261's Avatar
thanks guys!!! ill try it
by the way i have a 4 inch exhaust, custom grind 100 plate, and a bhaf, what south bend clutch do you recomend?
Old 10-06-2006, 02:00 PM
blue302stang's Avatar
might as well go with the ConFE clutch. It may be a little more expensive and a little overkill, but it gives you room to grow
Old 10-06-2006, 02:12 PM
v8440's Avatar
Must be an earlier shifter-the tool to remove mine (once you have removed the obvious 4 bolts holding it to the transmission) is a human hand. You reach out, grasp the shifter, and lift it out of the transmission.
Old 10-06-2006, 02:59 PM
98 changed the shifter tower. Early models took the screw driver method and late models bolt the shifter in. Either tower will interchange. There is also a difference in the way the 4x4 shifter works. A little late on the info but will help someones search later.
Old 10-16-2011, 10:39 PM
Received 1,332 Likes on 862 Posts
Anyone know is a chevy 4 bolt top plate off a NV4500 will work on a dodge NV4500?
Mkinner
09-21-2010 07:57 PM
Bogurt
03-05-2009 01:03 PM
nmen
07-22-2008 11:24 PM
SBishop
02-14-2004 05:21 PM
thumbs
10-29-2003 02:19 PM
Quick Reply: shifter removal tool
