Say I wanted a fresh set of injectors - what should i do?
Old 05-05-2007, 09:33 PM
Common's Avatar
Go with a larger HP injector or stockers?
When is a good time to replace injectors on a 12v?
How reliable are they?
Old 05-05-2007, 10:33 PM
WildBill's Avatar
I replaced my stock injectors at 300,000 miles - only because I wanted more power, they still worked just fine. With the #10 plate and a set of bigger injectors you will need a bigger turbo, and a beefier clutch. If your truck does what you need it to, just use a good fuel conditioner, and if over 100,000 miles you could just get an injector flush done.
Old 05-06-2007, 08:16 AM
Valv's Avatar
D.B. I wouldn't worry about injectors yet until you get a new clutch.
THEN install that # 10 you are dreading to add, remove the K&N and get a BHAF......and hang on.....
Have timing advanced a little to help mileage, if you rather, but I wouldn't go with injectors yet, give it a little time.
Old 05-06-2007, 08:22 AM
Common's Avatar
I look at the 10 every day and ask him if he's gonna be nice to me.
Old 05-06-2007, 08:47 AM
Valv's Avatar
Trust me, I had same feelings 6 months ago. Once I did it, I went back and adjusted it many times.
It's really nothing special, I also put a stock plate into my son in law instead of his killer #0
Seriously though, get a clutch in the budget, I was able to keep my stocker under control but I had to reduce power a lot, plus I couldn't tow heavy, it would have been too much slipping.
I had a guy quoting me a South Bend complete kit for $ 700.00, or get a Valair for less than $ 600.00
I know it might be a lot of money, but you have no way out if you start adding power.
Also read about the opinions with K&N, since I don't know what's the truth, I rather go with something else thank risk the engine, BHAF are well worth.
Geico266
02-22-2006 08:43 AM
WS6HUMMER
09-27-2005 10:24 AM
nicksort
06-06-2003 07:41 PM
Farmall
12-20-2002 05:54 PM
Fishcop
11-13-2002 08:45 PM
Quick Reply: Say I wanted a fresh set of injectors - what should i do?
