reg cab rear speaker size?
Old 11-30-2006, 02:12 PM
Registered
blackdiesel's Avatar
I ordered a coupla 6.5 rear speakers for my truck (along with a head unit, coupla front speakers, 2 amps and a sub) Now im kinda thinking that the rear speakers are acually 5.25??? Anybody know for sure? and what is that made out of back there? cause if they are 5.25" ill make my 6.5"'s fit
Old 11-30-2006, 02:40 PM
lews930's Avatar
the rear speakers are round. I just replaced mine. I believe they were 4 1/2
maybe 4 ". there is not enough room in there to install a larger speaker without cutting metal!
lewis
Old 11-30-2006, 03:09 PM
Registered
lewis
humm... ahh well. Ill either make them fit or.... make them fit. LOL
Old 11-30-2006, 03:24 PM
julang's Avatar
Speakers
lewis
How about front speaker size?
Old 11-30-2006, 05:47 PM
lews930's Avatar
front speakers will take oval speakers some where around 5 1/2 by 7 or 6 If you call or go by Best buy or Circuit city, they'll tell you what will fit in the truck. you may be able to do it on their website
lewis
Old 11-30-2006, 05:51 PM
Registered
uhh, the fronts are 6x9's but im putting 6.5 componets in the front and 6.5 two ways in the rear. a sub in the console and an amp to run the speakers and an amp to run the sub. and i think the rears are 5 1/4.
Old 11-30-2006, 06:22 PM
dslpower's Avatar
Speaker Size
I just changed mine out last night, the front door speakers are 6"x9", Pioneers bolt right in. The rear speakers in my 95 Are 5 1/2", all info I could find said they were 5 1/4". I got 5 1/4" ones and they almost did not make it to the screws that hold them in.
6.5" speakers wont work without cutting the hole larger. Or using an adapter or spacer plate.
Old 11-30-2006, 06:25 PM
Registered
if its possible, ill make em work
Old 11-30-2006, 06:58 PM
lews930's Avatar
There is enough room if you have a sawzall!
Old 11-30-2006, 07:56 PM
SIXSLUG's Avatar
I'd use a shear. Get one for cutting left or right and you can cut the metal in a circular direction. Its not that thick. A sawzall will shake the door and you violently when it starts to catch and wiggle the metal!
Old 12-09-2006, 08:33 AM
Registered
ah, i was much easier than i expected. all i did was screw the new mounting bracket over the hole from the previous speaker and slid the new one right in.
ptextreme
08-22-2010 08:06 PM
gts95
03-25-2009 11:09 AM
c-hawk
09-25-2008 10:33 AM
HOHN
03-28-2008 02:13 AM
csramsey640
12-24-2005 11:47 AM
Quick Reply: reg cab rear speaker size?
