reg cab rear speaker size?
I ordered a coupla 6.5 rear speakers for my truck (along with a head unit, coupla front speakers, 2 amps and a sub) Now im kinda thinking that the rear speakers are acually 5.25??? Anybody know for sure? and what is that made out of back there? cause if they are 5.25" ill make my 6.5"'s fit
front speakers will take oval speakers some where around 5 1/2 by 7 or 6 If you call or go by Best buy or Circuit city, they'll tell you what will fit in the truck. you may be able to do it on their website
lewis
lewis
uhh, the fronts are 6x9's but im putting 6.5 componets in the front and 6.5 two ways in the rear. a sub in the console and an amp to run the speakers and an amp to run the sub. and i think the rears are 5 1/4.
Speaker Size
I just changed mine out last night, the front door speakers are 6"x9", Pioneers bolt right in. The rear speakers in my 95 Are 5 1/2", all info I could find said they were 5 1/4". I got 5 1/4" ones and they almost did not make it to the screws that hold them in.
6.5" speakers wont work without cutting the hole larger. Or using an adapter or spacer plate.
I'd use a shear. Get one for cutting left or right and you can cut the metal in a circular direction. Its not that thick. A sawzall will shake the door and you violently when it starts to catch and wiggle the metal!
ptextreme
Aug 22, 2010 08:06 PM
gts95
Mar 25, 2009 11:09 AM
c-hawk
Sep 25, 2008 10:33 AM
HOHN
Mar 28, 2008 02:13 AM
