Quick Brake question
Okay so i am sitting at work thinking about this. And don't have the truck tore down in front of me.
Do i need to pull the hub off to get the rotor off? I was told that the whole hub assembly comes off together?
After looking at this picture of a 01 a 99 year truck should be the same on brakes correct?
I can just unbolt the caliper and pull the old rotor off correct?
Location: Ordered to Elizabeth City NC. rather be back in north Idaho
You know, now that you bring it up I'm brain farting. I'm pretty sure you can take the rotor off without pullin the whole hub out. I just can't remember how (I should...I had all that stuff off a couple months ago). I think you have to take off that big ole hub nut right there in the middle and then it'll come off. The hub assy don't come off untill you take off the four bolts in the back of the hub.
DTR's 'Go to Guy'
It depends.......3500 have to have the entire hub off to change rotors, and some 2500's did too. IIRC, it depends on what axle you have in the front and what GVW.
HorseHauler
13
03-12-2006 11:48 AM
