pot inplace of tps
Old Feb 7, 2007 | 03:24 PM
np205's Avatar
pot inplace of tps
I read what was in the sticky sbout it and just wanted to make sure on a couple of things. The main thing is when you replace the tps with a pot does your cruise control still work? I also was looking at the switch idea and wondered if I left the tps in, could I plumb in a od switch to turn on od at any time, or do I need something else to make the switch work.
Thanks,
Owen
Old Feb 7, 2007 | 05:17 PM
Yes, the cruise will still work.
If you install a mystery switch, everything will work as normal except when you flip the switch. All you're doing is grounding the OD circuit.
Old Feb 7, 2007 | 05:58 PM
np205's Avatar
Thanks for the info, I've got all sorts of stuff to do now.
Old Feb 7, 2007 | 07:30 PM
th_racer's Avatar
The replacement works great, I've been useing it for about 10 months now with 0 problems, cruise works and od button will still turn it off as norm.
whosdunit
May 17, 2014 08:54 AM
12von38`s
Feb 25, 2009 10:37 AM
Sootin
May 1, 2007 04:04 PM
92DIESEL
May 16, 2006 09:35 PM
DarrellB
Jan 1, 2003 02:36 AM
