Oil leak
Old Feb 5, 2007 | 04:42 PM
automeister3's Avatar
Oil leak
So I started my truck this morning came back outside and there was at least 2 quarts of oil on the ground . It appears to be coming from the oil filter o-ring but I haven't done an oil change recently checked the filter and it is tight. I found a similar thread on the pressure valve located on the top of the housing and im just wondering before sitting in 12 degree weather is this a common problem?
Old Feb 5, 2007 | 05:43 PM
I removed the filter and the o-ring is fine so I assume it is the valve???
Old Feb 5, 2007 | 05:52 PM
I haven't heard of anybody having trouble in that area. Clean it up good and start it again to see more clearly where the oil is coming from. There is a seal under the pressure regulator cover.
Old Feb 7, 2007 | 06:22 PM
New oil filter no leak. Dont see anything wrong with the old one but oh-well
Old Feb 7, 2007 | 06:41 PM
Redleg's Avatar
How messy is the area? Could it be comeing from the turbo oil line?
Old Feb 7, 2007 | 06:48 PM
darkvader's Avatar
sure you do not have two o rings up there?
Clark
Old Feb 7, 2007 | 08:06 PM
Yeah only one o-ring. The area was extremely messy but all cleaned up and no leaks
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
