PCM Gremlins?
Old Nov 23, 2007 | 07:58 PM
Montana2x2's Avatar
PCM Gremlins?
I just discoverd this forum and have an electrical problem that someone else may have dealt with. I have a 91.5 W-250 with the 5 speed trans and the wait to start light and the grid heaters come on from time to time when going down the road. Sometimes they just come on for a few seconds and other times they will be on for 30-45 seconds. It does not seem to matter if I'm on a good road or a rough road. Occasionally the water in fuel light comes on tho keep it company, but not too often. I have checked and cleaned all connectors, grounds and the connector into the PCM. I also ran an extra ground from the engine to the body. I replaced the sensor in the intake manifold and also the ignition switch thinking that I may be momentarily losing power to the PCM and having it reset and then heat the grids like when I first start it up. Any Ideas? If the wait to start and water in fuel are the only things that the PCM does in this truck can they be converted to the little black box that the earlier truck have? Thanks.
Old Nov 24, 2007 | 09:38 AM
Ace's Avatar
Ace
Dunno, but I'm waiting for mine to start acting up so I can ditch the WIF, start using a bigger fuel filter and put the grid heaters on a manual dash switch and decide when I want to use them or not.
Old Nov 24, 2007 | 06:32 PM
Montana2x2's Avatar
Probably the easiest thing to do in the long run.
Old Nov 24, 2007 | 09:24 PM
Yes, you could wire up a brain box out of an older truck.
Old Nov 24, 2007 | 10:27 PM
TOMTOM's Avatar
Is there any way to do away with the ecm completely?
TOMMY
Old Nov 25, 2007 | 11:11 AM
On your truck, not really unless you want to lose the cruise control and have to run the OD with a toggle switch.
Old Nov 25, 2007 | 04:10 PM
lowwag64's Avatar
Hi Dave,do you know anybody selling PCM's for our trucks?
Old Nov 25, 2007 | 04:12 PM
Any auto parts store should be able to get you one.
Old Nov 25, 2007 | 04:27 PM
lowwag64's Avatar
ok I never thought about NOS.
thanks
Big Perm
Dec 18, 2007 08:44 PM
Crimedog
Aug 16, 2004 11:52 PM
fixn2
17
Jun 30, 2004 09:21 AM
Monty
Nov 8, 2003 02:05 PM
FireNhole
Feb 22, 2003 11:51 AM
