Need help fast!!!
Old Nov 23, 2007 | 10:10 PM
06Wolvy's Avatar
Need help fast!!!
All righty ive ran into a slioght problem. Ive got a 89 cummins that i put new bosch 40hp injectors in 2 weeks ago. I also did a valve adjustment and tweaked the pump a little more while i was doin everything. The truck has been running great till today when it started getting a miss in it. It runs all right but had one heck of a miss to it. I dont hear the noise from the engine but you can hear it from the intake and the exhaust so what do i need to do? thanks for any and all help
Old Nov 23, 2007 | 10:16 PM
Free89W350's Avatar
You might have a dirty injector. With the truck running crack the injector line loose, VERY CAREFULLY, you should hear a difference in the way it runs with each one. If you crack one and the running condition doesn't change then that injector is your culprit.
Check in recent threads started by maxx250 I think that he had a injector go bad and a couple people explained what to look for. I will look for the tread and give you the link.
Ryan
BC847's Avatar
1st Generation Admin
Check the valve adjustment again. Perhaps things got loose/tight.
Old Nov 23, 2007 | 10:21 PM
Free89W350's Avatar
Heres that thread https://www.dieseltruckresource.com/...d.php?t=178644
It basically said what I said to try but I wanted to check for myself so I didn't steer you wrong.
Old Nov 23, 2007 | 10:38 PM
06Wolvy's Avatar
all righty thanks guy yall said the same thing i thought to try. I just hadnt tried them yet cause one its getting late and 2 i like to check with the guys that know theses things.
Old Nov 24, 2007 | 06:32 PM
06Wolvy's Avatar
well guys i opened up the injector line today and when open all of them changed the tune of the engine. I also rechecked valves to make sure i hadnt over tightened one and everything was in good shape. I decided too drive the truck down the road to see what i twas actually doing and the truck was just dead. She would build boost but was cutting out pretty bad and blowing a whitish gray smoke. I figure its fuel cause it doesnt smell like antifreeze. It would also pop oncein awhile out the exhaust kinda like a back fire. so where do i go next?
Old Nov 24, 2007 | 07:37 PM
rbrettctd's Avatar
With white smoke it sounds like an injector issue.
Old Nov 24, 2007 | 07:48 PM
boostedve's Avatar
maybe change the fuel filter...
Old Nov 24, 2007 | 09:33 PM
BC847's Avatar
Did you by chance adjust the IP timing? If so, perhaps you've gone WAY too far.
Old Nov 24, 2007 | 10:43 PM
CaptainChrysler's Avatar
I am leaning towards fuel filter. Mine plugged awhile ago, and it plugged fast. Ran fine from a stop sign and like 5 miles later could only go about 50 then 45 then 40...... When you tried to accelerate it blew white/ grey smoke. It was wierd cause it sounded like a gasser that was running out of fuel. Just kind of droned when you pushed the pedal farther than you had fuel to go. It did some poping too.
Is it posible that when it runs low on fuel pressure in the pump that the timing retards and that causes the white smoke? Or is it something else.
Old Nov 25, 2007 | 08:32 AM
powerrammaster's Avatar
Yes, I would say fuel blockage. I had an 8.3 on a truck that was white smoke, missing and poor acceleration/power. It was picking up crud in the tank and it plugged 2 filters before the the tank got cleaned.Fuel filter should help.
Old Nov 25, 2007 | 09:08 AM
maxx250's Avatar
Definitley fuel related bro,Ive been dealing with this mess for weeks now,had a bad #1injector ,changed it out,I still have white smoke (not as bad though)and the truck actually seems to run good,but still have a slight miss.I cracked my injectors last night and now Im thinking my # 3 has got some issues as well.Im gonna change the filter too just to eliminate that.This is all after putting in a new IP as well
Old Nov 25, 2007 | 06:00 PM
bgilbert's Avatar
You might try pulling the ebay injectors and reinstalling your stock injectors to see if that is the problem.
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
wwm
Feb 26, 2009 08:37 PM
Sam Turner2
Jan 11, 2008 03:32 PM
trik396
Mar 14, 2007 07:57 AM
