P0500?
Old Feb 15, 2008 | 10:41 AM
wurkenman's Avatar
P0500?
Got a code P0500 today and the truck does not move in any gear selected. I can shut truck off and restart and put in gear and it will gradually slide into gear and move about 20 feet or so then nothing. I pretty much know what the result will be (new tranny time) but is there anything else to check?
Thanks guys
Terry
Old Feb 15, 2008 | 01:48 PM
matthopp's Avatar
0500 is just a simple speed sensor code stating that your truck is moving when it shouldnt or vice versa....though it is likely related to your tranny, the code isn't really telling you anything that you dont know.
Old Feb 15, 2008 | 10:04 PM
afoulk's Avatar
I've also been told that if you sit for awhile and hold the idle up manually, it'll set that code. makes sense....I didn't have that code until the cold weather came and I would hold my rpms around 1200 to help warm it up faster. I'll have to wait till springtime to see if the code goes away.
Old Feb 15, 2008 | 11:17 PM
wurkenman's Avatar
Then the code probably is related to my trying to get my truck in motion, but the trans had a much different idea. Looks like the tax refund is already spent
Old Feb 16, 2008 | 09:53 PM
BluMtnRam's Avatar
My truck will throw P0500 from either the high idle that you guys mentioned or if I spin the rear tires when it's slick. If I'm not mistaken a certain number of key cycles/starts and the code will disappear. I believe the ABS system is
part of it's trigger.
2002 Ram 2500, 4x4, SB, SLT, HO, 6sp, 4.10's, LSD, BHAF, gauges, smarty
Old Feb 17, 2008 | 02:08 AM
Clunk's Avatar
Talking
I had to sit with the shifter in neutral for about 15 seconds in my '92 after starting the motor to let the torque converter fill up after sitting several hours.
I get the P0500 after spinning the tires excessively too. It goes away on it's own if I can contain my 'ol Leadfoot a week or so
Old Feb 18, 2008 | 11:28 PM
SIXSLUG's Avatar
Mine threw that code on Friday when I ran it at 1200 rpm while I ate my lunch. I ran it for about 10 minutes to defog the windows. I found the code Saturday afternoon during my usual "light maintenance" session. Kurt
KUMMINZ1983
Jan 9, 2007 12:40 AM
K2Cummins
Dec 24, 2004 09:41 PM
figure_9_pro
Dec 5, 2004 08:29 AM
BillH
16
Sep 10, 2004 08:51 AM
More Power
Jan 20, 2004 10:58 AM
