P-Pump oil leak
Old 12-07-2006, 07:17 AM
schoust's Avatar
P-Pump oil leak
Ok guy's I was looking for fuel leaks because I have been loosing prime again as of late when I came upon an oil leak at the rear of the pump,dose anyone know of anything that might be the culprit here??
Old 12-07-2006, 07:24 AM
Dave88LX's Avatar
Governor lever cover plate?
Old 12-08-2006, 05:45 AM
schoust's Avatar
Is the gov. lever almost at the rear of the pump? If so that might be where it's coming from??I had a guy do a 3k gov. spring kit recently is there somthing he might have disturbed when doing it???
Old 12-08-2006, 09:11 AM
Dave88LX's Avatar
Gov lever adjustment is done from the rear of the pump. When he did the springs, he may have come from the side, in which there is a large plug on the rear drivers side of the pump that may be leaking.
Old 12-08-2006, 09:15 AM
plow's Avatar
And if he went through the top it could be the AFC leaking.
Old 12-08-2006, 09:18 AM
~Angry Tractor~'s Avatar
When I first got my truck I thought the IP was leaking but I found it was the O ring on the oild dipstick above the IP. It leaks down on the pump and the oil works its way around the pump.
Old 12-08-2006, 10:13 AM
Dave88LX's Avatar
There's also an oil feed line I believe coming to the top rear of the AFC housing.
Old 12-09-2006, 12:28 PM
schoust's Avatar
Thanks for the sugestions guy's I think I will need to clean things up a bit when it warms up to try to pin point where it's comming from.
coalburner_77
17
11-07-2018 07:36 PM
george7941
11-28-2009 09:28 PM
donhov
26
01-06-2006 07:29 PM
Bobcat698
11-21-2005 09:19 PM
PCarnathan
08-15-2005 09:59 AM
Quick Reply: P-Pump oil leak
