Overdrive Button
Old 01-16-2004, 07:35 AM
richard's Avatar
Overdrive Button
Had a thought the other day.
Is there a way to wire the overdrive button to keep the overdrive off at all times?
So when you shut the key off the overdrive button does not have to be pushed again on startup?
So when you start the truck, the overdrive is off instead of on?
Rich
Old 01-16-2004, 08:22 AM
berner's Avatar
I've seen a rewire kit somewhere that does exactly what you want. I'm at work and can't surf too long to find it. Maybe somebody else knows or I'll look this weekend.
Old 01-16-2004, 09:38 AM
infidel's Avatar
It's not as simple as just switching some wires around but not too hard. The od off button is a momentary on switch, it just sends a pulse that toggles the od from off to on with each pulse. What some guys do is wire a relay in parallel to the od switch that is only triggered on when the the starter motor is engaged. Essentially the relay pushes the button for you, if it takes two tries to start your truck (not likely) od will be on.
Old 01-16-2004, 02:27 PM
berner's Avatar
That sounds like it would work just fine. I imagine that's what the rewire kit I saw does. Buying a relay and wiring it yourself would probably be 1/4 the price.
Old 01-16-2004, 02:44 PM
richard's Avatar
I figured that the rewire kit was something like that.
I have relays and will probably just wire it in myself.
Cost, just time.
Thanks for the replies
Rich
Old 01-17-2004, 09:52 AM
Rhino's Avatar
I have done this to my truck. It was very simple, took maybe 1/2 hour tops. Here is a wiring dagram:
Old 01-17-2004, 04:37 PM
infidel's Avatar
Rhino, what happens with the light on the button that tells you when OD is off with this modification?
Does it mean anything anymore?
Old 01-17-2004, 06:19 PM
Rhino's Avatar
The light still functions as normal. When you start the truck the light will be illuminated indicating the OD is off. When you push the button to turn OD on the light goes out.
Old 01-17-2004, 06:31 PM
Bob Wagner's Avatar
http://www.dodgeram.org/tech/mods/tr..._inverter.html
Subliminal
01-21-2014 09:55 PM
Tedonlin150
02-04-2010 11:37 AM
can17
11-10-2008 02:53 PM
rackshakermac
09-08-2003 07:28 PM
Quick Reply: Overdrive Button
