np205 front output problem
Old Dec 18, 2007 | 11:43 PM
feveree40's Avatar
I was under the truck tonight and found that the front output shaft of my t-case has a significant amount of play vertical as well as probably .050" endplay. I just put the front drive shaft on a couple weeks ago, and everything was tight. I only drove with the hubs locked in for maybe 10 miles, and in 4X4 for only a mile or so. Anything above 35 with the hubs locked vibrates a lot because of the steep diveline angle. Do you think I could have killed the output bearings that quickly? thrust washers? I'm going wheelin this weekend at roush creek, so i really need the 4X4. Will the t-case be alright, or will I hurt it even more?
Old Dec 19, 2007 | 08:16 AM
apwatson50's Avatar
With a 6" lift do you have a clearanced CV joint?
Old Dec 19, 2007 | 08:39 AM
MoparMarv's Avatar
Mine has the same play as well in the front flange. I have not had a chance to see whats causing it. I'm taking a guess its the nut that holds it on is just loose.
Old Dec 19, 2007 | 11:52 AM
feveree40's Avatar
Yes, its clearanced enough to turn without binding, but the angle so steep that it still vibrates.
I was hoping the same, but I took the flange off last night and re torqued it, but the play is the same. Any other ideas?
Old Dec 19, 2007 | 03:18 PM
Hot Dawg's Avatar
I had the same prob when I first got my truck. I had to tighten up the nut holding the flange on. No prob since. Check your splines to see if there worn, if not its prob a bearing issue.
diesel402004
Apr 25, 2014 08:33 AM
MARF75
Apr 10, 2012 01:48 PM
DNRCustoms
May 19, 2008 08:52 AM
andyr354
Jul 25, 2006 11:27 AM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
