new quad tow box and codes
Old Aug 13, 2005 | 05:31 PM
badram's Avatar
Hey everyone , new to the site and to diesels , and already my 1st problem , I made my 1st purchase from Larry at D.T.R. Thanks for all the suggestions . I recieved the Quad tow box first and installed it right away real simple , ran great for four days and then It coughed and sputtered and shut down while doing 60 mph on the freeway ,pulled her over and restarted no prob. for 5 miles then did it again ,plugged in the bypass ,ran fine for about 15 min then check engine light came on and stalled I then moved the connections at rail and map , when I touched the map the truck went nuts and stalled , so i removed the harness and ran the truck about 25 miles back home and all was ok . by the way code p0192 shows now, any suggestions on what I should do would be appreciated . Sorry long first post.
2005 2500 8000 MILES NEVER A PROB. TILL BOX
Old Aug 13, 2005 | 08:19 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Sounds like a loose connection, recheck those plugs
If that doesn't do it, give Jeremy a call at 1-888-842-6572 He will get you straightened out.
Old Aug 13, 2005 | 09:40 PM
badram's Avatar
i'll give him a call on mon. just thought someone might have been through this already , I did try to reinstall and same prob occurs. Thanks Larry.
Old Aug 13, 2005 | 10:11 PM
qzilla's Avatar
Almost definately a connection problem if it had issues with the bypass in.
Look inside the plugs both ours and the factory connectors to make sure no pins have been pushed down or might be making a bad connection. I would start with the MAP connection first as that sounds like your problem.
The code is almost definately caused by the map sensor.
P0192
Fuel Rail Pressure Sensor Circuit Low Input
If the MAP had a funny reading it probably thought your fp was too low for the boost that it was reading.
The other thing you need to look at is the 12pin connector. Make sure all of the pins are ok in it as well.
Old Aug 13, 2005 | 11:21 PM
metal_miner's Avatar
P0192
Does code P0193 "Fuel Rail Pressure Sensor Circuit High" relate to the map sensor too? Or popping the pressure relief valve? Got this code with running the Juice yesterday on 5x5.
Thanks!
Old Aug 14, 2005 | 09:56 AM
badram's Avatar
Thanks Qzilla I will give that a try today .
Old Aug 15, 2005 | 03:26 PM
badram's Avatar
Yep , bad connection at the map sensor , removed it and pinched the female conn. tighter and now everything is normal ....for now...more mods to come.
Old Aug 15, 2005 | 06:16 PM
Admin Team Leader
Hey Mike! Glad to hear you found the problem
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
rockhound
Aug 3, 2007 11:56 AM
flinn101
Dec 14, 2005 09:43 PM
coobie
Oct 17, 2005 10:53 AM
