about the new diesel
Old 07-25-2006, 11:48 PM
12vstrokethis's Avatar
i have started seeing stickers that say something on the lines of do not use if newer then 2007. Any way what i am getting to is what is the difference and from what i have been hearing that it will mess up all of my seals. what do i need to do? i am thinking just add some cetane boost or about a gallon or 2 of used motor oil.
Old 07-26-2006, 10:01 AM
infidel's Avatar
This is the source of much needless worry, you don't have to do anything at all.
The stickers you are seeing only indicate that the pump still has the same low sulfur diesel that it's had since 1994.
Even when the new ultra low sulfur diesel starts appearing more and the sticker changes saying that the fuel is ok for 2007 engines you need not do anything.
By law the fuel must have the same lubricity as the old fuel
Old 07-26-2006, 12:16 PM
Chass's Avatar
That sticker would sure scare me if I were driving a 2007 rig though! Its blatantly clear that you should not run that fuel in a 2007 diesel. It says it will damage your engine.
The attendant that I spoke with says that all the guys with the newer trucks drive away and get new gas elsewhere.
Why would the newer trucks require the newer fuel? Buildups maybe?
Chass
ct
Old 07-26-2006, 01:52 PM
Greguw's Avatar
From what was told to me the sulfer level was dramaticlly dropped from 500 parts permillion to 15 ... and that is what lubes our injectors ...
I did notice a smell in the new diesel ...I started to add a quart of 2 stroke oil to every tank .
Greg
Old 07-26-2006, 07:38 PM
infidel's Avatar
The level of sulfur does nothing for the fuel, it's the act of removing it that lowers the lube value of the fuel. The refiners are well aware of this and add back lube agents.
High sulfur fuel will clog the particulate scrubbers that will be required on all new onroad diesel engines starting Jan 1, 2007. So far very few of these engines are on the road.
By the time the vehicles with scrubbers are on the road the new ultra low sulfur diesel will be widely available. In fact many of us are using it now without their knowledge.
Read this https://www.dieseltruckresource.com/...d.php?t=110490
Old 07-26-2006, 11:24 PM
i might not be understanding that link right, but what i do understand is that it will mess up the models later than 2007. If i am right what can we do to pervent this.
Old 07-27-2006, 10:11 AM
infidel's Avatar
Originally Posted by 12vstrokethis
i might not be understanding that link right, but what i do understand is that it will mess up the models later than 2007. If i am right what can we do to prevent this.
Just burn ULSD. The law is 80% of the diesel produced in the US after Oct 1st 2006 must be ultra low sulfur diesel. The 2007 models that can be harmed by current diesel aren't due out till Jan 1 2007. Should give plenty of time for ULSD to be available most everywhere. In fact it will be hard to find anything but ULSD come Jan 1.
Old 08-07-2006, 11:12 PM
kelownadiesel's Avatar
I heard that it will produce less power ,which I dont really believe.Any ideas?
Old 08-08-2006, 09:55 AM
infidel's Avatar
I've read the big rig guys, who put on a ton miles from which to make a qualified determination, are reporting one half to one mile drop in mpgs with ULSD.
Old 08-10-2006, 10:48 PM
timeagain's Avatar
Not supposeed to affect our, older trucks!! waiting to hear from the rest if this is the case!!
Chrisreyn
04-24-2006 07:22 PM
LanceK
04-13-2006 06:32 PM
DirtEater
03-31-2006 02:28 PM
OOPS
08-28-2004 07:15 PM
akchameleon
03-19-2003 12:39 AM
Quick Reply: about the new diesel
